And is there any more information that can be retrieved with the listener? For instance if I wanted to know what was coded in a shot could I display that as well?
Sent: 03-03-2025 05:05
Subject: how to create panel that displays video duration from overdrive?
Hello Nick!
What you need to do to view the clip name, is create a label in dashboard, and set the name as "n/a" and the id as "clipName Timer03" (replacing the Timer03 with the ID of the timer position in rundown Control).
Then in the task for the listener :
you need to make sure the following code is there to rename the clipnames(it will replace the existing "Parse Timers" section):
// Parse Timers
if (typeof (retObj.timers) != 'undefined')
var timers = retObj.timers;
for (var i = 0; i < timers.length; i++)
var styleInfo = "";
// Set Style Info for running timers
if (timers[i].running) {
// Get values for countdown timers and set style based on value.
if (timers[i].direction == "Down") {
var warning = timers[i].currentValue;
var close = warning.indexOf("+0:0");
var over = warning.indexOf("+0:00");
var overover = warning.indexOf("-")
if (over == "0") {
styleInfo = "<fg#FF0000>";
} else if (close == "0") {
styleInfo = "<fg#F6DF3C>";
} else if (overover == "0") {
} else {
styleInfo = "<fg#00FF00>"
} else { // Timers counting up
styleInfo = "<fg#00FF00>";
} // end if timers running
else
// Set style info for NOT running timers
styleInfo = "<fg#CCCCCC>";
//ogscript.debug(timers[i].timerId);
ogscript.rename(timers[i].timerId, timers[i].currentValue + styleInfo);
// Process User Defined Timers
if (timers[i].type == "user")
ogscript.rename("User" + timers[i].timerId, timers[i].userTimerName);
if (timers[i].type == "static")
ogscript.rename("clipName " + timers[i].timerId, timers[i].clipName);
}//end parse timers
Andreanne Tremblay
OverDrive Product Prime
Reading, United Kingdom
Sent: 03-02-2025 23:15
Hello Andreanne.
Reviving this old thread. I downloaded the Floor Director Panel you shared. I've set my server IP, and it works great.
One thing I'm trying to achieve though, is having a box that shows wich clip is cued in a certain server channel. In my Overdrive server webpage, in Device, Floor Director, I can open the REST API. In the timers endpoint section, I can see wich clip is cued in the "coresponding timer" of my server channel. I've tried coding Dashboard to get this information, but no luck. What should be the command line in Dashboard ?
Nick Morneau
Control Room Support
BELL MEDIA - Montreal
Canada
Sent: 10-09-2024 04:11
This is the latest version, but you can customize your panels to fit your needs. The CG timing information is not available in the Floor Director at this time.
Andreanne Tremblay
Sent: 10-03-2024 15:58
thanks Andreanne! 2 quick questions... is this the latest version available? and is there a page that displays CG timing info? or am I able to configure to add that info? thanks so much!
Bobby P
Supervisor
Sent: 10-03-2024 09:06
Hello Bobby!
Try this link : https://transfer.rossvideo.com/f/df6f02b7eb22662f
Have a nice day!
Andreanne Tremblay
Sent: 10-02-2024 22:10
Hi Andreanne, would you be able to re-share those Dashboard pages? I believe we do have FloorDirector now. Thank you!
Bobby P
Supervisor
Sent: 07-07-2023 05:22
Hello Greg,
Here is a link to some panels you can use with Floor Director :
https://transfer.rossvideo.com/f/b7c9d30af9cdd041
Once you open the panel, you want to edit and find the "listener"(as shown here) and you need to put the IP address of the OverDrive Server, and the port 8760.
Andreanne Tremblay
Sent: 07-05-2023 16:09
Hello Andie,
Any FloorDirector example panels for Dashboard? I see raw JSON via HTTP, but unsure how to link that into Dashboard. Thanks!
Greg Roberts
Production Supervisor
WANF- Atlanta
Sent: 01-12-2023 10:46
Hello Bobby,
There is a feature called Floor Director that is available in OverDrive and this gives you access to the timers and more information about the rundown (what shot is on-air, prepared etc.)
Depending on your current license(if you have Premium) it may already be available and just need configuring. If this is the case, in your OverDrive server webpage, it would be under the "Device tab" as "Floor Director".
Let me know if you see it and I can help you for the setup.
Andreanne Tremblay
