  • 1.  How to create Start/Stop Encoding Streams macro button in Panelbuilder
    Posted 06-03-2026 12:34
    Hello, I'm somewhat new at creating custom panels using Panelbuilder so hopefully this is an easy one.
    I'd like to be able to start and stop the encoding streams on my Cobalt 9992-ENC Pacific OG Cards using a single button radio button or toggle. There are 2 cards, each with 3 streams. So I'd like to have two separate buttons, one for each card.
    The name of the parameters are Encoder State (0x2054), (0x2448), (0x283c).State Values are 0=stopped and 1=running
    There's also a confirmation button that needs to be triggered in order to except each parameter change, so a macro for that should be created as well: (0x207e), (0x2472), (0x2866). State Values 0=Apply
    Let me know if should provide any more info, Thanks!
    davidc Coleman
  • 2.  RE: How to create Start/Stop Encoding Streams macro button in Panelbuilder
    Posted 06-04-2026 17:20
    Hi David, I've attached an example panel below to help out with your question.
    In the example panel, we use the parameter card1state to store whether the streams for card 1 should be started or stopped when we hit the confirmation button. It's a temporary variable, and has the states 0 = Stopped, 1 = Running, but doesn't directly change the Encoder State parameters.
    The confirmation button has an attached task that when clicked, takes the value of card1state and sets the values of card1Stream1, card1Stream2, card1Stream3 accordingly. You can substitute card1Stream1, card1Stream2, card1Stream3 for your Encoder State parameters in your own panel.
    Then, we repeat the same with another set of parameters and buttons for Card 2.
    Please let me know if you have any questions!
    <abs contexttype="opengear" gridsize="20" id="_top" keepalive="false" style="">
       <meta>
          <params>
             <param access="1" constrainttype="INT_CHOICE" name="Card1 State" oid="card1state" precision="0" type="INT32" value="0" widget="radio-toggle">
                <constraint key="0">Stopped</constraint>
                <constraint key="1">Running</constraint>
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Card2 State" oid="card2state" precision="0" type="INT32" value="0" widget="radio-toggle">
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Card2 Stream2" oid="card2Stream2" precision="0" type="INT16" value="0" widget="text-display">
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Card2 Stream1" oid="card2Stream1" precision="0" type="INT16" value="0" widget="text-display">
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Card2 Stream3" oid="card2Stream3" precision="0" type="INT16" value="0" widget="text-display">
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Card1 Stream1" oid="card1Stream1" precision="0" type="INT16" value="0" widget="text-display">
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Card1 Stream2" oid="card1Stream2" precision="0" type="INT16" value="0" widget="text-display">
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Card1 Stream3" oid="card1Stream3" precision="0" type="INT16" value="0" widget="text-display">
             </param>
          </params>
       </meta>
       <param expand="true" height="100" left="40" oid="card1state" showlabel="false" top="80" width="320"/>
       <param expand="true" height="100" left="680" oid="card1Stream1" showlabel="false" top="80" width="80"/>
       <param expand="true" height="100" left="800" oid="card1Stream2" showlabel="false" top="80" width="80"/>
       <param expand="true" height="100" left="920" oid="card1Stream3" showlabel="false" top="80" width="80"/>
       <button buttontype="push" height="100" id="confirmationButton1" left="400" name="Confirm Changes" top="80" width="160">
          <task tasktype="ogscript">
    /*! block id=1002,1003 !*/
    params.setValue('card1Stream1', 0, params.getValue('card1state', 0));
    /*! block id=1005,1003 !*/
    params.setValue('card1Stream2', 0, params.getValue('card1state', 0));
    /*! block id=1006,1003 !*/
    params.setValue('card1Stream3', 0, params.getValue('card1state', 0));
     &lt;block id="1002" type="param_setvalue" x="358" y="10" w="318" PARAM="[root, Params for New%20CustomPanel3.grid, Not In Menu, Card1 Stream1 (card1Stream1)]" PARAM_DATA="_top&amp;amp;card1Stream1[0]" VALUE="ID:1003" /&gt;
    &lt;block id="1003" type="param_getvalue" x="10" y="10" w="318" PARAM="[root, Params for New%20CustomPanel3.grid, Not In Menu, Card1 State (card1state)]" PARAM_DATA="_top&amp;amp;card1state[0]" /&gt;
    &lt;block id="1005" type="param_setvalue" x="358" y="126" w="318" PARAM="[root, Params for New%20CustomPanel3.grid, Not In Menu, Card1 Stream2 (card1Stream2)]" PARAM_DATA="_top&amp;amp;card1Stream2[0]" VALUE="ID:1003" /&gt;
    &lt;block id="1006" type="param_setvalue" x="358" y="242" w="318" PARAM="[root, Params for New%20CustomPanel3.grid, Not In Menu, Card1 Stream3 (card1Stream3)]" PARAM_DATA="_top&amp;amp;card1Stream3[0]" VALUE="ID:1003" /&gt;
    /*!!&lt;checksum&gt;3a543b3dc2cf12b3a479e6d4fd63495c&lt;/checksum&gt;!!*/</task>
       </button>
       <label height="40" left="40" name="Card 1" style="txt-align:west;" top="40" width="60"/>
       <label height="40" left="680" name="Stream 1" style="txt-align:west;" top="40" width="60"/>
       <label height="40" left="800" name="Stream 2" style="txt-align:west;" top="40" width="60"/>
       <label height="40" left="920" name="Stream 3" style="txt-align:west;" top="40" width="60"/>
       <param expand="true" height="100" left="40" oid="card2state" showlabel="false" top="480" width="320"/>
       <param expand="true" height="100" left="680" oid="card2Stream1" showlabel="false" top="480" width="80"/>
       <param expand="true" height="100" left="800" oid="card2Stream2" showlabel="false" top="480" width="80"/>
       <param expand="true" height="100" left="920" oid="card2Stream3" showlabel="false" top="480" width="80"/>
       <button buttontype="push" height="100" id="confirmationButton2" left="400" name="Confirm Changes" top="480" width="160">
    params.setValue('card2Stream1', 0, params.getValue('card2state', 0));
    params.setValue('card2Stream2', 0, params.getValue('card2state', 0));
    params.setValue('card2Stream3', 0, params.getValue('card2state', 0));
     &lt;block id="1002" type="param_setvalue" x="358" y="10" w="318" PARAM="[root, Params for New%20CustomPanel3.grid, Not In Menu, Card2 Stream1 (card2Stream1)]" PARAM_DATA="_top&amp;amp;card2Stream1[0]" VALUE="ID:1003" /&gt;
    &lt;block id="1003" type="param_getvalue" x="10" y="10" w="318" PARAM="[root, Params for New%20CustomPanel3.grid, Not In Menu, Card2 State (card2state)]" PARAM_DATA="_top&amp;amp;card2state[0]" /&gt;
    &lt;block id="1005" type="param_setvalue" x="358" y="126" w="318" PARAM="[root, Params for New%20CustomPanel3.grid, Not In Menu, Card2 Stream2 (card2Stream2)]" PARAM_DATA="_top&amp;amp;card2Stream2[0]" VALUE="ID:1003" /&gt;
    &lt;block id="1006" type="param_setvalue" x="358" y="242" w="318" PARAM="[root, Params for New%20CustomPanel3.grid, Not In Menu, Card2 Stream3 (card2Stream3)]" PARAM_DATA="_top&amp;amp;card2Stream3[0]" VALUE="ID:1003" /&gt;
    /*!!&lt;checksum&gt;64c391d3966dd0780dcee420c60f6c07&lt;/checksum&gt;!!*/</task>
       </button>
       <label height="40" left="40" name="Card 2" style="txt-align:west;" top="440" width="60"/>
       <label height="40" left="680" name="Stream 1" style="txt-align:west;" top="440" width="60"/>
       <label height="40" left="800" name="Stream 2" style="txt-align:west;" top="440" width="60"/>
       <label height="40" left="920" name="Stream 3" style="txt-align:west;" top="440" width="60"/>
    Michael Quach
  • 3.  RE: How to create Start/Stop Encoding Streams macro button in Panelbuilder
    Posted 06-05-2026 11:20
    Thank you, this looks like it should do the trick!
    My next challenge is how should I go about associating these fancy .PNG graphics with the parameters so that the respective stream start, stream stop, and confirm buttons illuminate or change when clicked. ideally the start/stop buttons would stay lit until the confirm button is pressed
    Thanks again!
    David Coleman
    AV Systems Engineers
  • 4.  RE: How to create Start/Stop Encoding Streams macro button in Panelbuilder
    Posted 06-05-2026 11:22
    And is there a way to change the way the Encoder RTMP Status parameter looks? Maybe a simple font color change or what the indicator lights looks like
    David Coleman
  • 5.  RE: How to create Start/Stop Encoding Streams macro button in Panelbuilder
    Posted 06-05-2026 14:39
    Hi David,
    If you're okay with using a single toggle button for the stream stop and start, you can edit the following for the card1State and card2State params:
    • Change the widget hint from Toggle Buttons (22) to Toggle Button (13)
    • Under the Style tab -> Toggle On -> Background (URL), set the "Start Stream" background image
    • Under the Style tab -> Toggle Off -> Background (URL), set the "Stop Stream" background image
    The end result will look like this:
    To change the Encoder RTMP Status parameter, you can navigate to the Style tab -> Font/Text Style, and change the Foreground Color setting:
    Michael Quach
