Sent: 10-20-2023 03:06
Subject: How to play a non-looping roll/crawl with unknown number of child scenes?
LOL - I was just going to update my post to say you seem extremely busy (based on your comments in all the other posts) and I'm good. And you replied anyway. You're amazing and a huge testament to Ross support. I hope you get all your actual work finished as well!
Bryan Block
Malick Media
Sent: 10-20-2023 02:52
disp is short for display (visible) and data is the object I have tied to data.
What you have created is exactly what I was describing, nice work!
Sent: 10-20-2023 02:22
Hi, Simon. I got this working and am pretty happy with it.
There's one thing I'm not sure I understood correctly - the section on copying text fields ("disp.Text = data.Text"). I'm not sure what 'disp' and 'data' represented in your example, so I did the following.
Since we're grabbing two fields from each row, I created one set of text objects (set to static) that are visible and animated, and a second set that isn't visible but has the source set to datalinq. In this example, only one row (pair of text fields) is visible at a time.
On the first frame of the scene director I set the visible text fields to the datalinq text fields with a copy script (dim statements omitted for readability):
Scene.GetObjectByName("DL_Event", eventData)
Scene.GetObjectByName("DL_Person", personData)
Scene.GetObjectByName("EventName", eventText)
Scene.GetObjectByName("PersonFullName", personText)
eventText.Text = eventData.Text
personText.Text = personData.Text
When the first set of fields is center screen, a check script compares the datalink key with the 'FinalRow' user input value - if it's equal or greater, I pause the scene; otherwise I increment the key, refresh DL and continue the animation off the screen.
Scene.GetDataLinqKeys(keys)
keys.GetKeyByName("Row", key)
Scene.GetObjectByName("LastRow", lastRow)
Scene.GetObjectByName("DLK", dlk_Row)
Scene.GetSceneDirectorByName("default",sd)
if key.AsString >= lastRow.Text
sd.Pause
Else
key.asString = cInt(key.AsString) + 1
dlk_Row.Text = key.AsString
Scene.RefreshDatalinqs
End If
When the text is finally off the screen, I use an event to loop to the beginning, where the copy script resets the visible text objects to the new datalinq values.
Is this the process you were describing? Is there a more efficient way to do the above? If I want more than one row on screen, I'll just create another pair of text objects and adjust the timing to loop through and update each of them.
Thanks again for your help and support.
Bryan Block
Malick Media
Sent: 10-13-2023 11:21
At the point when you copy you'll want you animation to be in a state where the text isn't visible or you'll see it jump when it updates.
Sent: 10-13-2023 11:19
no worries, what you want on the scene director in in the same script but after the above script,
or on another script event just after is the copying of the script.
dim disp, data as xpTextObject
Scene.GetObjectByName("Disp", disp)
Scene.GetObjectByName("Data", data)
Sent: 10-13-2023 11:01
Brilliant. I'll play with this. Thank you!
Bryan Block
Malick Media
Sent: 10-13-2023 10:52
dim keys as xpDatalinqKeys
dim key as xpDatalinqKey
keys.GetKeyByName("datakey", key)
Scene.refreshdatalinqs
I wouldn't use any of that stuff at all I would just use a normal scene.
The I'd use a datalinqkey
Then where you have the <n+1> I would replace that with <%datalinqKeyName>
Then I would use script on a scene director to increment that by 1 each time the text moves up the screen.
Sent: 10-13-2023 10:49
We should have access to the data. Using the datalinq key method you described, how would you set up the scenes or scene group to iterate through data rows?
Bryan Block
Malick Media
Sent: 10-13-2023 10:39
In the past I've either had a manual entry or if I have access to the data I've had them add a field with a number of rows / nodes that I can check.
I then use a datalinq key to keep count which I update with a scripting during each animation.
At the rest point of each animation I copy between text objects from the one connected to data to the visible one.
Sent: 10-13-2023 10:32
I can read and modify script; haven't written many from scratch but did some VB coding in a past life.
There aren't any Datalinq methods in the SDK so I doubt you can query the number of rows in a source, or iterate through rows within a single script. Perhaps you could read the text property of a presumed unique row before it goes online, save it to an array (but where?), then compare it to anything already in the array to determine if a loop has started.
How would you approach this with scripting? I know there are manual ways for the operator to grab and massage the data prior to going live, but it wouldn't always be possible or practical without setting limitations on external updates, which kinda defeats the point of XPression and Datalinq in the first place.
Bryan Block
Malick Media
Sent: 10-13-2023 09:03
Personally at this stage, I'd probably write a script to do this instead.
Do you have any experience in this?
