Hi Paul,
Sorry we don't have a guide to setup control of a BMD Hyperdeck from a Vision. But below are some handles, hope they help.
1. Setup Ethernet Communications on the Vision for the Hyperdeck
- Home > Setup > Installation > Com Setup
- You will need the IP address of the Hyperdeck and port number 9993.
- Remember to turn on the 'remote' option of your HyperDeck.
2. You will need the list of Hyperdeck commands (pg66 of the Hyperdeck manual).
https://documents.blackmagicdesign.com/UserManuals/HyperDeckManual.pdf3. Now go to Custom Controls > Start Recording > Special
- Insert a 'RossTalk TypeInCmd' using a Hyperdeck command.
- The TypeInCmd custom control allows you to enter a manual RossTalk command into a custom control.
Aaron
