  • 1.  Ignore Object Alpha Checkbox Persistent
    Posted 09-13-2025 17:21
    When editing multiple objects in a scene, the Ignore Object Alpha checkbox does not change states when moving between objects. For example, when I check the box on one object and then move to another object, it will remain checked even if it is not checked on the second object. If I want to turn it on on the second object, then, I have to double-click it to enable it on that layer.
    David Argo
    Freelance Graphic Design & Implementation
    david@davidargo.com
  • 2.  RE: Ignore Object Alpha Checkbox Persistent
    Posted 09-16-2025 07:11
    David,
    Are you checking the "Ignore Object Alpha" box on the Quad in the Object Inspector, or from the Material Editor of the material bound to those objects?
    Jeff Mayer
  • 3.  RE: Ignore Object Alpha Checkbox Persistent
    Posted 09-17-2025 22:14
    Hi Jeff,
    I am checking it on the quad in the inspector.
    David
