  • 1.  Ignore the DSK
    Posted 04-03-2026 23:59
    Hi everybody. I have a CC that does some crazy things to the DSK. It takes key 3 and 4, builds a mask around both and does some different fade times. What I get is a lower 3rd that fades in the just the logo part of a lower 3rd, pauses a few frames then fades in the text part of the lower 3rd, does a hold then fades the whole thing out and then resets all the keys to normal. It's my way of adding some level level of style to a simple fade ointment of a lower 3rd. I do this all by recalling 3 memories.
    In an upcoming show, I need to add a bug that stays the whole time. Is there a way to build this so that one DSK (the bug) is ignored by all this? I want control as to when to add this bug that is outside what all the other keys are doing. A "no matter what is happening, ignore anything DSK 4 is doing"  button.
    San Francisco United States
  • 2.  RE: Ignore the DSK
    Posted 04-04-2026 00:18
    Hi Danny,
    I'm a freelance Director/TD and have also run into a few cases of CCs acting strangely.
    In some cases I solved the problem by rebuilding the CC from scratch.
    In your case are you triggering any mem or state recalls? If so check the Live Assist/Mem menus in Dashboard and make sure the save and recall areas are set the way you want.
    Another item to check is if you have any MEs set to follow each other.
    Cheers,
    Mike
    Michael Minkoff
    Las Vegas United States
  • 3.  RE: Ignore the DSK
    Posted 04-04-2026 13:22
    The DSK and the CC are acting correctly. What I want is something I'm note sure is capable.
  • 4.  RE: Ignore the DSK
    Posted 04-05-2026 03:50
    This is kind of what Recall Over ride Attributes are for.
    Being able to set them to Forced Recall or Forced Never Recall.
    That can make it so that Memory recalls will not control it -- that said as well some of your other memories you are doing your Custom Control recalling memories could look to make sure it only recalls the elements it should recall via the attributes system.
    As for completely "ignore" other commands.. not really.  Does this DSK have to be under other keyers?  or can it be a final after keyer?  maybe put a MiniME downstream of PGM and add it that way?
  • 5.  RE: Ignore the DSK
    Posted 04-06-2026 12:41
    Recall Override! Works perfectly. Thanks for reminding me of that feature.
  • 6.  RE: Ignore the DSK
    Posted 04-06-2026 17:16
    When Brian Ford wrote the Memory Attributes for Vision he mentioned "we should have added a way to have Recall Overrides.." so when we were doing it for Carbonite I thought "what would Brian want to improve it..."..
    Great feature -- though it can at times catch people :) it is a double edge sword.
