This is an iNews error that the MOS command itself is too large. INews doesn't care about the file size of the scene, only the amount of data that needs to go into the MOS payload. In the past, it would produce this error if the MOS command exceeded 32,000 characters…not sure if that limit has changed. Is there a way to reduce the amount of published objects and/or properties in the scene that get entered in the MOS plugin?
Jeff Mayer
