  • 1.  Installation File
    Posted 04-23-2025 19:27
    Hello!
    Is it safe to assume that in Dashboard/Carbonite, the Personality file stores all things located in the Personality menu and the Installation file holds all things in the Configuration file?
    I was curious if I could break out the Multiview layout as a separate item.
    San Francisco United States
  • 2.  RE: Installation File
    Posted 04-23-2025 22:39
    for the most part that is correct ... ViewControl does have the Icons and mapping for the CCs / events in the personality while the actual MV assignments for layout and mapping is in installation.
    MV is not separate from the Config -- but you could build a custom control that sets every aspect of you MV with the push of a button and thus in the CCs which can be saved separate from Pers and Config.
