Hi Rick,
TriggerPlay is controlled via midi.
Caprica connects to it by using the "SpotOn" type device, which also uses Midi.
In the Port Configuration Summary table, double-click a REMOTE# port in the Port column.
In the Configure REMOTE# panel, click Audio Server.
Click SpotOn.
Click Network Settings.
Use the following settings to configure the Network Settings for your Sigma Broadcast SpotOn:
•Ethernet Role - Client
•Remote IP Address - IP address of the computer running the SpotOn audio playback software
•Remote Port - 4650
•Local IP Address - 0.0.0.0
•Local Port - 0
•Protocol - TCP
Click Apply Changes to save the device settings.
Click Done to close the Configure REMOTE# panel.
NOTES:
•OverDrive can play Cut/Button 1 to 320 inclusively.
•Playing Cut/Button 0 from OverDrive or a Custom Control means ALL STOP (stop all playing buttons).
JB Morrison
Product Manager; OverDrive and Caprica
