  • 1.  Issue with the crawl.
    Posted 01-23-2026 09:09
    Hi Everyone,
    I'm running a crawl that has been functioning well, but suddenly it has developed a glitch. While the crawl is in progress, it jumps between headlines and then stops, after which it works fine again. This issue seems to occur consistently around the same headlines. Could this be a problem with the Expression (which I double-checked and confirmed my work is correct) or could it be related to the RSS feed? Thank you.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 2.  RE: Issue with the crawl.
    Posted 01-26-2026 10:53
    Is your crawl set to seconds and are the text objects in the child scenes Datalinq'd?
