Sent: 10-03-2023 04:21
Subject: Issues with Crawl - animating text and publishing text
Thanks Simon, this script works perfectly!
Paulo Dias
Sent: 09-14-2023 10:24
please see attached.
Sent: 09-12-2023 19:22
Thanks Simon for the reply,
I did play with all those settings before and no luck, I wasn't able
to achieve the desired results. Can't seem to restrict the output of
the crawling text in order to make it loop faster (from the moment it
disappears behind the mask (left side) and it starts showing again
(right side). Note that I'm not trying to restrict the output of the
parent scene, only the text that crawls (child).
About issue number 2, I also used a mask to "out" the crawling text
but this is not the effect that I wanted. I wanted to animate the text
down (along with the background bar on the parent group) or fade it at
least.
And yes, I would like a sample of the script you used to be able to
publish the crawling text. That would be helpful.
Thanks again,
Paulo Dias
Sent: 09-11-2023 08:30
have you tried playin with this settings ?
Also if the page is cropped to its size unless there is an object in the scene, are you sure you don't have something like a quad background or something in there, that will make it play the full width?
2. Normally I cover the text with a mask in the parent scene, need to be in front on Z and cannot be in a layer group.
3. I have a solution for this but requires scripting, would you like a sample?
