I understand there are two ways to apply DataLina values to the objects in the scene, on the Layout or on the Sequence.
Now I create same looks with either way, on the Layout and on the Sequence, and found significant difference on the times to be "online" after double-clicking on the Sequence, as follows;
Setting Datalinq values on the Layout : it takes 2-3 seconds to be online.
Setting Datalinq values on the Sequence : less than 1 second to be on line.
Is this a know issue?. Still I would like to set Datalinq values on the Layout because I want to duplicate the scene to generate different versions which inherits the Datalinq datasets I created once. This would be reasonable than set Datalinq on the Sequence.
I'm creating a scene which shows scores, players names/positions/numbers, game clock, Home and Away teams' names. This is for Soccer games.
Takuya Hoshikaya
