I can see from the image you sent me that you have it set up correctly.
I would put some debug messages in your GPI scripts to see if they are being fired or not.
Also try making a keyboard shortcut to fire them just to check they working on the sequence side.
Sent: 01-16-2024 15:50
Subject: Keyboard / GPI Mapping - Layout vs Sequencer issue
I have an animation template that works great in Layout mode, where my custom keyboard commands trigger animation playback from Dashboard (select range of frames defined). However, nothing happens on the sequencer side. I have other Dashboard controls that work just fine (Toggles, Sliders), it's just the buttons with RossTalk assigned to GPI Trigger ID's that are not working. Any thoughts on a setting/preference I'm missing?
Chris Jordan
Graphic Artist in Charge
NBCUniversal
