Agree with Paul - Looks like you are sending two events which will cause the switcher to pause.
You can disable this feature by setting the personality for the Double Press to Ignore:
https://help.rossvideo.com/solo/Tasks/Setup/Personality/AutoTrans2.html
That page in the manual will give you the options and how to navigate the menu to disable it.
Sent: 06-26-2024 23:02
Subject: Keyer "Half On"?
On the physical control panel you can pause a transition if you hit auto-trans again during the transition (this behaviour goes as far back as the analog 210/216 series). Maybe your Companion setup is sending the command twice within that transition duration window?
Paul
