I've developed a keypad that I can type the scene ID and press TAKE button to control the Xpression sequencer. In my view, everything was set correctly, however, the keypad does not work as expected. Could you help me, please? You'll find the code bellow. The Xpression server has IP address 10.79.31.134 and my machine IP address 10.79.31.128.
Code lines:
<abs baseurl="file:/C:/Users/Abekas/Desktop/Several_Panels/XPression_Panels/TesteKeyPad.grid" bottom="-2" contexttype="opengear" gridsize="20" id="_top" keepalive="false" left="-1" right="1" top="2" virtualheight="921" virtualwidth="1498">
<meta>
<ogscript handles="onkeyrelease" targetid="number_entry">checkEnter(event);</ogscript>
<ogscript handles="onkeyrelease" targetid="keypad">checkEnter(event);</ogscript>
<params>
<param access="1" maxlength="0" name="take_id" oid="take_id" type="STRING" value="" widget="text"/>
<param access="1" constrainttype="INT_NULL" name="Frame_buffer" oid="0x2" precision="0" type="INT16_ARRAY" value="1;1" widget="spinner"/>
</params>
<api>function addNumber(num) {
ogscript.focus("keypad");
var value = params.getValueAsString('take_id', 0);
new_value = value + num;
params.setValue('take_id', 0, new_value);
function clearNumber() {
params.setValue('take_id', 0, "");
function checkEnter(event){
var keyCode = event.getKeyCode();
var keyText = event.getKeyText(keyCode).toLowerCase();
if (keyText == "enter"){
sendTake();
function sendTake(){
if (value == "" || value == null){
ogscript.debug("No number is entered");
else{
ogscript.debug("TAKE " +value);
rosstalk.sendMessage('10.79.31.134', 7788, 'TAKE '+value+':0;1:0');
clearNumber();
}</api>
<context contexttype="opengear" id="XPression.1" objectid="10.79.31.134:8020:XPression" objecttype="XPression"/>
</meta>
<param expand="true" height="40" id="number_entry" left="140" oid="take_id" showlabel="false" top="60" width="140"/>
<label height="40" left="60" name="Take ID:" style="txt-align:west" top="60" width="60"/>
<abs height="300" id="keypad" left="60" top="140" width="720">
<simplegrid cols="4" height="180" left="0" rows="3" top="0" width="260">
<button buttontype="push" name="1">
<task tasktype="ogscript">addNumber(1);</task>
</button>
<button buttontype="push" name="2">
<task tasktype="ogscript">addNumber(2);</task>
</button>
<button buttontype="push" name="3">
<task tasktype="ogscript">addNumber(3);</task>
</button>
<button buttontype="push" name="Take">
<task tasktype="ogscript">sendTake();</task>
</button>
<button buttontype="push" name="4">
<task tasktype="ogscript">addNumber(4);</task>
</button>
<button buttontype="push" name="5">
<task tasktype="ogscript">addNumber(5);</task>
</button>
<button buttontype="push" name="6">
<task tasktype="ogscript">addNumber(6);</task>
</button>
<button buttontype="push" name="Clear">
<task tasktype="ogscript">clearNumber();</task>
</button>
<button buttontype="push" name="7">
<task tasktype="ogscript">addNumber(7);</task>
</button>
<button buttontype="push" name="8">
<task tasktype="ogscript">addNumber(8);</task>
</button>
<button buttontype="push" name="9">
<task tasktype="ogscript">addNumber(9);</task>
</button>
<button buttontype="push" name="0">
<task tasktype="ogscript">addNumber(0);</task>
</button>
</simplegrid>
João victhor Mariano
