for anyone else that has this issue, I also used the same method to get my dashboard OUT of Fullscreen, my laptop for some reason or another wouldn't send the SHIFT+F11 shortcut to get out of full screen (I enabled Fullscreen via the menu)
restarting dashboard would remember the setting, so I used the above method with -false and fixed the issue.
Tom Wilson
Demo & Training - Solutions, Oceania
Sent: 04-14-2023 16:59
Subject: Launch dashboard in fullscreen
Hi Sam
Yes, this launcher argument is still the best way to do this (particularly if you are running Windows or Linux).
For Windows, you can create a shortcut to DashBoard and add the additional arguments that way. You could also edit the DashBoard.ini file to do this (but this is overwritten each time you upgrade to a new version).
James Peltzer
