Hi Ryan!
The autosqueeze and word wrap features will fight against each other (Same problem, different solutions: Text too long, what do?!).
That said, your inclination is right! This is something I'd tackle with Visual Logic. I've given it an attempt, try it out yourself and see if you like it, or even see if you can change it to work better!
I have 3 text objects, a hidden (in the final version) that is published so that people can type into that, a 2nd object that handles the word wrapping with adjustable word-wrappiness tied to half of the length of our source text object, and finally a display text object that takes the word wrapped text, but then also gets scaled down x-wise based on how much the word wrap exceeds the 2-line parameters. It seemed to work better giving a bit of an offset from the minimum word wrap value, and I'm sure that could be adjusted.
Zachary Fradette
United States
