Hi All,
This is round two of building off the success of an earlier script, where I was able to assign a texture from a file of numbered image files. I'm trying to "level up" and have it import from a folder of randomly named images, but by the index from it's list location. This compiles, but something just isn't connecting to pull the image. I've been looking at it too long and would appreciate any assistance. It's under OnSetText in the text editor and typing in a URL triggers the Scene update:
' Declare variables and initialize as Nothing
Dim path As xpTextObject
path = Nothing
Dim Quad As xpBaseObject
Quad = Nothing
' Get the ItemIndex
Dim ItemIndex As Integer
ItemIndex = 1 ' Replace with your desired ItemIndex
' Establish a text object for the file path
Scene.GetObjectByName("Source Folder", path)
' Get the image path from the TextObject
Dim imagePath As String
imagePath = path.Text
' Declare variables to cover all possible file extensions
Dim extName1, extName2, extName3 As String
extName1 = ".jpg"
extName2 = ".jpeg"
extName3 = ".png"
' Get all files in the folder
Dim fs As Object
fs = CreateObject("Scripting.FileSystemObject")
' Declare folder here before using it
Dim folder As Object
folder = fs.GetFolder(imagePath)
Dim files As Object
files = folder.Files
' Create a Quad object
Scene.GetObjectByName("Image2", Quad)
' Check if the ItemIndex is within bounds
If ItemIndex >= 1 And ItemIndex <= files.Count Then
' Get the file at the specified index
Dim file As Object
file = files.Item(ItemIndex - 1) ' Adjust index to start from 0
' Get the file name and set the volatile texture files for the Quad object
Dim fileName As String
fileName = file.Name
' Set the volatile texture files for the Quad object, and applies regardless of file name extension.
Self.GetParent(Quad)
Quad.SetVolatileTextureFile(0, imagePath & "\" & fileName + extName1)
Quad.SetVolatileTextureFile(0, imagePath & "\" & fileName + extName2)
Quad.SetVolatileTextureFile(0, imagePath & "\" & fileName + extName3)
Else
End If
Chris Jordan
Graphic Artist in Charge
NBCUniversal
