Hi Alan,
Yes, there's a straightforward way to do this.
You can save your desired layout and then use the -layout LAYOUT_NAME command-line option to load it at startup. You can do this by adding that option to shortcuts. That should open the soft panel when DashBoard starts.
Kiran Adhikari
