  • 1.  Logging Data Change with Dashboard/XPression
    Posted 03-07-2025 11:00
    Hello all,
    I have created a scorebug in XPression which features a section with a sponsor logo which rotates every 30 seconds. This sponsor logo material is driven by a Dashboard parameter which contains the filepath to the logo, which is then linked to the material field in XPression (there may be an easier way to accomplish this, too, that I'm not thinking of!). This works great for game day usage, but presents an issue when I have to present a playback report since the As Run log only sees the scorebug as one play, rather than one every 30 seconds.
    Does anyone have any ideas on how I could run a log of every time the material changes while the scene is on air? I have not seen an obvious way to do so in either Dashboard or XPression.
    Thank you!
    David Argo
    Freelance Graphic Design & Implementation
    david@davidargo.com
  • 2.  RE: Logging Data Change with Dashboard/XPression
    Posted 03-07-2025 11:55
    This may help.
    https://rossvideo.community/communities/community-home/digestviewer/viewthread?GroupId=199&MID=22228&CommunityKey=91812bfd-9393-4a3f-8a74-7f8035df130e
