Hi Takuya,
Not sure if you've figured this out and I'm late to the game or I'm over explaining but here's what I had to do...
Where the Datasource says [ExcelFile] map that to you excel spreadsheet. I have mine saved locally on my D drive but it can be anywhere as long as your PC has permissions. I've added a screen shot of my set up. Sorry if this is info you already know though or if it's not what you're going for.
Donny Swanson
Graphic Designer, Broadcast
TVO (TVOntario)
Toronto Canada
Sent: 10-21-2024 19:10
Subject: Looking for a way not to use Excel's legacy sharing.
Yes, I choose Excel (XLSX) in the ADODB, and push the "Select Excel file…" button. And I choose "All Files" to find my xlsm file in the dialog box.
I think Microsoft.ACE.OLEDB 12.0 supports not only xlsx but also xlsm (https://www.connectionstrings.com/ace-oledb-12-0/xlsm-files/). Am I correct?.
Takuya Hoshikaya
Sent: 10-21-2024 12:02
Are you using the ADODB data source and the ACE driver?
