Working with two different continuous animations at the same time can be frustrating. I suppose another way is to have a dedicated scene director that only controls the fade up, movement left to right, and then the fade out. Add to that a jump to a specific frame and it might do what you want. I'm not sitting at my Xpression right now to give it a try, but this might take care of what you need. If you want to go that way, I can fire up my Xpression and give it a try. Good Luck.
Malcolm Thorpe
Sent: 10-06-2023 15:52
Subject: Looping a Texture - Flare that moves across a lower third bar
Hi Paul
Thank you for your note. I watched the continuous animation video and I thought it could be that before I posted on the Ross site. Just not easy, yet, to get the flare to travel from left to right on the lower third bar then dissolve out. Then dissolve back up at the start point and travel back down the bar again. Need this to keep looping.
Any tips on this?
Michele Lee Hampton
Graphics Operator
Hermosa Beach, CA
Sent: 10-05-2023 23:39
Sounds like a job for continuous animation.
https://www.rossvideo.com/resources/ross-university/continuous-animation-basics/
Skip ahead to 19 minutes for an example of a flare/glow animating over a lower third.
Paul
