Hello Geraldo,
I am sharing with you the Solution Brief that includes information about LUT support. https://documentation.rossvideo.com/files/Brochures/Connectivity/Ultrix/Ultriproc%20Solution%20Brief.pdf
I am less familiar with the Ultrix side of things, but I do know that supporting LUT requires a X-series I/O board (HDX, MODX) and the ULTRIPROC-3DLUT license.
If you don't mind, could you directly message me your email address or contact number? I will connect you with my colleagues in Australia, who can assist you further with your requirements.
Aaron
Sent: 03-06-2024 19:25
Subject: Luts into Carbonite Dashboard
Thank you, Aaron. Do you have any links/tutorials on how Ultrix can support LUTs?
Cheers,
Geraldo Rodrigues
Events Technician
Sydney
Sent: 03-05-2024 23:55
Hi Geraldo,
Carbonite does not support the application of LUT profiles. However, there are other products in the Ross portfolio (Gator Toolbox, Ultrix) that do support LUT.
Within Carbonite, there are Proc Amps and Color Correctors that can adjust the video signal, but LUT profiles cannot be applied to it.
Aaron
