Hi Andrew,
Unfortunately, I have not seen or heard the issue that you encountered. I suggest trying a few different things and see if the glitch persists.
1) Which FTP client are you using? Personally, I have been using Filezilla.
2) Try a different USB stick. Note that it should be formatted to FAT32.
3) Upgrade Carbonite Ultra to the latest firmware (v7)
https://www.rossvideo.com/support/software-downloads/carbonite-ultra/- While the release notes does not mention anything related to our issue here, but I see that improvements were made to the USB access.
- Plus there are other bug fixes and new features since v4.
If the glitch persists, I recommend reaching out to Tech Support to investigate this further.
https://support.rossvideo.com/hc/en-us------------------------------
Aaron
