Hi Simon!
Thank you so much for this advice. Unfortunately, I cannot put all of the text in the same group, so I am grouping by text colors (white title text + white info text, yellow title text + yellow info text). Still, that solution was working really well! However, I find that whenever I get to the fourth bounding box height equation in VL, the whole thing breaks and none of the VL works. Would you happen to have a solution for this issue? Is there maybe something wrong with my VL?
Sarah Husney
Graphic Designer
Sent: 10-18-2023 18:33
Subject: Making Text Always Centered (with VL?)
Put the text in a group so you can position where you want it.
Take the bounding box height of the text and devide by 0.5 and put that to the position of the text y position.
The use the position of the group to put the text where you want it.
Sent: 10-18-2023 15:16
Center vert or horizontal?
