We are new Ultrix users and we are trying to find the best and easiest way to achieve some stuffs.
With the MADI IN/OUT for emb-deemb audio channels, we don't need external emb-deemb anymore.
But in the past, it was "easy" to manage, I explain:
As the embbeders were externals, they were on our old Harris router as destinations and sources.
So, for example a PGM output we wanted to attach some audio, we routed it to the EMB, then the "PGM with audio" was avalaible as source (the embedder output was a source).
Then it was easy to pass it to more destinations (externals, feeds, etc.).
Is there a way to achieve something like that with a "virtual" source on the Ultrix, or something ?
For the moment, we have to make 2 Xpoint to put somewhere an embedded output:
- Xpoint of the video source to, for example, an external output or a feed (destination)
- Xpoint of the "emb" source (which correspond to a group of MADI inputs channels) to the same destination
And we have to achieve this for every destinations we need to pass an embedded signal.
I think there is also a huge risk of error (forget to route the "EMB" source to the destination => result: video without the audios..)
For the de-embedding part, we found an easy way to get back something identical to the past:
We made some destinations "DMB 1" "DMB 2" etc.. with the requested MADI outputs slices
We just have to route sources we'd like to do de-embedding to those destinations and the corresponding channels are routed to the right MADI "slices"
Thanks !
Arnaud Cresp
NOTELE
