Steve,
Without seeing your scene and combined script, I'm not sure exactly why these won't work in a single script. If you've been copying the entire second script to the end of the first, try putting a
` at the beginning of lines 2-4, since the first three 'declaration' commands in the second script (dim ... as xp...) won't run twice, like this.
'Hide the Crawl
'This script will play forwards & back.
dim scene as xpScene
dim fb as xpOutputFramebuffer
dim scenedir
engine.GetOutputFramebuffer(0, fb)
if fb.GetSceneOnLayer(0, scene) then
if Scene.Name = "CRAWL" then
if scene.GetSceneDirectorByName("HIDE", scenedir) then
if scenedir.position >= 40 then
scenedir.PlayRange(40, 0)
else
scenedir.PlayRange(0, 40)
end if
end if
end if
end if
'pause the crawl
'dim fb as xpOutputFramebuffer
'dim scene as xpScene
'dim scenegroup as xpSceneGroup
if scene.IsGroup then
scenegroup = scene
scenegroup.stop
end if
My other suggestion would be to leave both of these scripts separate as they are now, but to run them with a single Keyboard Shortcut in a Group. You an add a group function to your Keyboard Shortcuts, then make your two Script Actions children of that Group. Enable the option to run all children actions when the group is triggered, and both scripts actions should run together. It would look something like this:
This would also allow you to keep each script separate, so you could run each on it's own if you ever needed. Keep us updated if either of these work for you.
Jeff Mayer
