I didn't save it but here are the settings;
Make sure you're not trying to send the scene to the same framebuffer that the sever channel is trying to use as you can see above the server channel I want to use as a texture has no framebuffer assigned.
Sent: 03-18-2025 11:32
Subject: Material Server Channel Shader
Hi Simon,
Can you send me your project, I'm sure I'm missing something.
Karim Lakehal
VIDELIO - AMP VISUALTV
Paris France
Sent: 03-18-2025 10:41
For me this works as you described;
