You need to store your RState of the switcher before saving your file set.
The RState is the "Memory 0000" so to speak. there are even separate RState Attributes for some of the global items... however the MEs are ALWAYS stored and recalled for all items..
Thus you can setup your MEs exactly how you would want them setup for when you Reset the switcher.
Note that the RState does not trigger on a Setup recall.. you recall the setup files and then do the Reset All (ALL/STORE together in a keypad) and it will do the RSTATE load... or go to the memory area of Rstate in Dashboard or panel menu to press the load Rstate.
