Each ME has 8 GB of Cache for the 4 Channels. 1/3 have 4GB and 2/4 have 4GB
That is per ME and you can access any media store on any ME or Output.
Anything that is in the that local cache will instantly load you don't need to Eject something to load something just load it.. If not in cache it will load to cache and remove items that are not in channels to make space. If something is in a channel it will never be auto ejected.
There is no expanding the Cache it's physical hardware. Your total cache spread across all 4 MEs is 32 GB over 16 channels.
Beyond that an attached XPression or Tria Server would be how to have Extended Clip and Media.
Sent: 11-08-2023 01:36
Subject: Media Store Acuity Ultrix
Okay will give that a try. We are working with 4k File sizes. Is there an option to increase the cache size?
Rory Guthrie
Sent: 11-08-2023 01:30
Hi Rory,
A media cannot be loaded into a channel directly from the cache. However, if the media is already in the cache, it can be loaded into a channel of the same cache via Custom Control. For example, if a media is in Cache 1, a Custom Control can be programmed to load it into either Channel 1 or 3.
Aaron
