I have a media wipe that uses a DVE push right. When played from dashboard using the auto trans button, it behaves as expected .. a DVE push right. Flip flop off. Direction Forward.
When I add this effect to a custom control, the DVE does a push right only once. Subsequent CC recalls it is a push left. It doesn't flip flop. It just decides it's now a push left from this point on. When you go back to dashboard and press auto trans (or on the panel), it's also a push left, even though push right is highlighted.
In dashboard, tapping and highlighting push left and then tapping and re-highlighting push right returns the correct DVE move until the CC is used again.
The CC has nothing special going on that I can think of. It loads the media, puts ME P/P into Media Wipe, pauses 5 frames, does an ME P/P auto trans, pauses 100 frames and put the transition panel back into DISS. I've used this CC with many media wipe transitions. This is the first using it with a DVE. In any case, I rebuilt the CC for this specific effect thinking this is where the flaw is.
I have attached a link to a video that may be helpful.
https://drive.google.com/file/d/1kN77AThpHR4m-WNba5nxQTlI-JyJ_15C/view?usp=sharing
