Yeah. I figured you would have checked all that. I'd give Tech Support a call since this is a change from what has happened for you in the past. Tech Support is good at Ross. I screw things up and they get out of it all the time.
San Francisco United States
Sent: 09-27-2024 14:12
Subject: MediaStore Issue / After Effects & PNGS
Hey Danny,
Everything is named correctly, and I have the same issue with TGA and just still images.
Colin Murphy
Game Day Technician
OSEG
Sent: 09-27-2024 13:21
Hi Colin,
You may have already checked this but make sure the naming structure is correct. I'm away from my gear but I know the sequence needs to start at a specific number and have a certain amount of digits. The other thing I would check is your AF output file size.
