No need of a 12 channels Mira+. You can review the clips synch with 1 output.
With Mira. when you save a clip, you save all of the angles with the exact same timecode. So when you load the clip in you PGM you can easily change the angle by toggling the Soft Keys to change the angle. Again, these angles will be synch.
If you need to review something before saving a clip, you can rewind with the Rotary Dial or the rewind button, you'll be in Playback mode and then use the Soft Keys to change the angle and again, all the angles will be perfectly synch.
Feel free to reach out if you want to schedule a demo with us.
Thank you
Isabelle Berthiaume
Senior Demo & Training Product Specialist
Prime, Video Servers
Montréal ,Canada
