I was just looking for a way to directly manipulate the contents of a struct.
Using getters and setters to handle multiple parameters was a bit slow in execution.
Sent: 12-16-2025 06:49
Subject: Modify parameters based on the Choice parameter within the STRUCT
No probs, there are other ways perhaps. I've changed the other 'struct' to 'struct_array' - you can nest struct arrays within another struct array, the param at the end still gave issues until changed to a 'string_array' however.
<?xml version="1.0" encoding="UTF-8"?><abs contexttype="opengear" id="_top" keepalive="false"> <meta> <params> <param access="1" name="buttonData" oid="buttonData" type="STRUCT_ARRAY" widget="default"> <value> <subparam access="1" constrainttype="INT_CHOICE" name="selected" precision="0" suboid="selected" type="INT16" value="2" widget="checkbox"> <constraint key="0">zero</constraint> <constraint key="1">one</constraint> <constraint key="2">two</constraint> <constraint key="2">three</constraint> </subparam> <subparam access="1" maxlength="0" name="button" precision="0" suboid="button" type="STRING_ARRAY" widget="default"> <value>fed</value> <value>fed</value> <value>4gryy</value> <value>3</value> </subparam> </value> </param> <param access="1" maxlength="0" name="rename" oid="rename" type="STRING" value="4gryy" widget="text"/> </params> </meta> <param expand="true" height="449" left="108" oid="buttonData.button" showlabel="false" top="96" width="390"/> <param expand="true" height="64" left="532" oid="rename" top="109" width="255"/> <param expand="true" height="62" left="550" oid="buttonData.selected" top="193" widget="default" width="233"/> <button buttontype="push" height="59" left="546" name="do rename" top="294" width="236"> <task tasktype="ogscript">var target = params.getValue('buttonData.selected', 0);//params.setValue('buttonData.button.'+ target +'.name', 0, params.getValue('rename', 0));params.setValue('buttonData.button', target, params.getValue('rename', 0));</task> </button> <button buttontype="push" height="63" left="548" name="toJSON" top="369" width="236"> <task tasktype="ogscript">var struct = params.getAllValues("buttonData"); var json = params.valueToJson(struct); var string = JSON.stringify(json, null, 2); ogscript.debug(string);</task> </button></abs>
Richard Crutwell
Ross Video UK
Sent: 12-16-2025 05:51
Thanks for the reply.
I wanted to create a sports coder usable across various sports, and thought creating root params per sport would make API creation and management easier.(Like basketball.team.1.member or soccer.team.1.member...)
After trying various approaches, I reached the same conclusion as you.
It seems that if you modify a Constraint within a structure after the Script has cached it, it doesn't work properly.
For now, I understand that's just how it is.
Thanks for testing it.
Keisuke Nagata
Sent: 12-16-2025 04:33
It looks like the struct is reverting to a cached value, or default value. I noticed that the Struct Array is nested inside a struct, is there a reason for this?
If not, I'd recommend separation for these two, it appears to work without the nested structure.
<?xml version="1.0" encoding="UTF-8"?><abs contexttype="opengear" id="_top" keepalive="false"> <meta> <params> <param access="1" name="buttonData" oid="buttonData" type="STRUCT" widget="default"> <value> <subparam access="1" constrainttype="INT_CHOICE" name="selected" precision="0" suboid="selected" type="INT16" value="1" widget="checkbox"> <constraint key="0">zero</constraint> <constraint key="1">one</constraint> <constraint key="2">two</constraint> <constraint key="2">three</constraint> </subparam> </value> </param> <param access="1" name="button" oid="button" type="STRUCT_ARRAY" widget="default"> <value> <subparam access="1" maxlength="-1" name="name" suboid="name" type="STRING" value="1" widget="default"/> </value> <value> <subparam suboid="name" value="2"/> </value> <value> <subparam suboid="name" value="3"/> </value> <value> <subparam suboid="name" value="4"/> </value> </param> <param access="1" maxlength="0" name="rename" oid="rename" type="STRING" value="2" widget="text"/> </params> </meta> <param expand="true" height="449" left="108" oid="button" showlabel="false" top="96" width="390"/> <param expand="true" height="64" left="532" oid="rename" top="109" width="255"/> <param expand="true" height="62" left="550" oid="buttonData.selected" top="193" widget="0" width="233"/> <button buttontype="push" height="59" left="546" name="do rename" top="294" width="236"> <task tasktype="ogscript">var target = params.getValue('buttonData.selected', 0);params.setValue('button.'+ target +'.name', 0, params.getValue('rename', 0));</task> </button></abs>
Richard Crutwell
Ross Video UK
