  • 1.  Mos Plugin and Datalinq
    Posted 06-25-2026 21:06
    I am using DataLinq to make a drop down list of Team groups from an Excel file. Then it drives the rest of the info in the scene. In the sequencer it works nicely but when loading the template in Octopus I get the error "Failed to Load DataLinq source."  I have seen similar post in earlier discussions but I am not 100% sure of the solution. Any direction would be appreciated.
    David Rock
  • 2.  RE: Mos Plugin and Datalinq
    Posted 06-26-2026 11:13
    David,
    For Datalinq User Input Controls, the MOS plugin reads Datalinq sources from the Gateway's configured Datalinq Server, not necessarily the project's Datalinq Manager. So you'll want to make sure the same Datalinq Server your project is pointing to is also configured here in the XPression Gateway and that the Datalinq Server is enabled in those Gateway settings:
    Jeff Mayer
  • 3.  RE: Mos Plugin and Datalinq
    Posted 06-26-2026 15:57
    Thank you so much...I will check with our tech. Will post how it goes. Thanks
    David Rock
  • 4.  RE: Mos Plugin and Datalinq
    Posted 06-26-2026 15:58
    If Jeff's suggestion does not fix it please also provide your version and build number.
  • 5.  RE: Mos Plugin and Datalinq
    Posted 06-27-2026 14:49
    Well got the ip address sorted. But now encountered a new issue. I am seeing the groups to select but when I select one I am getting an error. Check the pics. Running Xpression v12.5 build 6135
    David Rock
  • 6.  RE: Mos Plugin and Datalinq
    Posted 07-02-2026 11:43
    [deleted]
  • 7.  RE: Mos Plugin and Datalinq
    Posted 07-02-2026 11:44
    I think could be fixed by newer build of 12.5?
    version 12.5 build 6143 (April 22, 2026)
    [fixed] HTML Plugin will tolerate a text field that is using an undefined global list
    [fixed] HTML Plugin Radio Buttons would fail if another field had no published properties
    [fixed] HTML Plugin could not edit Datalinq Key fields. Introduced in 12.4.6091
  • 8.  RE: Mos Plugin and Datalinq
    Posted 07-03-2026 13:32
    NOPE!!! I installed the latest version still got the error. Smh
    David Rock
  • 9.  RE: Mos Plugin and Datalinq
    Posted 07-06-2026 10:22
    Can you export the scene or project and send it to me to test?
    gmillward@rossvideo.com
  • 10.  RE: Mos Plugin and Datalinq
    Posted 07-24-2026 10:51
    Sent the scene.....any luck?
    David Rock
