That's right, when mosart send commands for overlay graphic it's working, but when trying fullscreen, it doen't work.
Back in june 2022 we upgraded from an older version of XPression, to a 10.0 as I remember.
Since then, we have not been able to load fullscreen.
Don’t know if anything changed since ver. 9 or what we upgraded from.
Sent: 06-16-2023 17:28
Subject: Mosart to XPression
Currently this is a bug or limitation of XPression, it won't be possible to correct on the XPression side without a new build of XPression. It looks like you are on 10.5 5535. I will investigate if this is something we can change.
I think the fastest solution right now will be to change Mosart so that it doesn't use Target ID 0.
We can see from your logs that Mosart does use other target IDs, so it must be possible to change it from using target ID 0.
15-06-23 17:10:36.856: Incoming (raw): W\1192\100\Mark Bundgaard\mabu@tvsyd.dk\\15-06-23 17:10:36.856: Incoming: write page, source id: 100 target id: 119215-06-23 17:10:36.857: Executed: Created Take Item ID: 1192 from Template ID: 10015-06-23 17:10:37.209: Incoming (raw): W\1193\602\f163.png\\15-06-23 17:10:37.209: Incoming: write page, source id: 602 target id: 119315-06-23 17:10:37.210: Executed: Created Take Item ID: 1193 from Template ID: 60215-06-23 17:10:37.231: Incoming (raw): W\1194\200\Skrydstrup\Danmark l<C3><A6>gger op til at tr<C3><A6>ne ukrainske piloter\\15-06-23 17:10:37.231: Incoming: write page, source id: 200 target id: 119415-06-23 17:10:37.231: Executed: Created Take Item ID: 1194 from Template ID: 20015-06-23 17:10:37.253: Incoming (raw): W\1195\602\vind3.png\\
Sent: 06-16-2023 17:18
I don't know if I can change what mosart uses, not sure how or where…
How can XPression correct it?
I don't know where there is a bug or config error, but seems something is wrong on either Mosart or Xpression, but can't find it…
Tue Sandbæk
Director / TV-Technician
TV SYD
Sent: 06-16-2023 16:43
This looks like either a bug in XPression...or...XPression isn't supposed to support Take Items with Take ID 0 at all. XPression always fails to create Take Items with Take ID 0 from CII commands.
Whenever a write command using target ID 0 is used, XPression creates a take item with the same take ID as the source ID (scene ID). If you use any target ID besides 0, it always works correctly.
It could be a bug, but I think its more likely that Take Items with Take ID 0 are just not supported and shouldn't be possible to create at all. You'll notice that the Fast Recall system also fails to trigger Take ID 0 correctly as well. Can you use something other than Target ID 0 for your Mosart workflow?
Here is a example of how XPression corrects the wrong Take Item from the write command when the target ID is 0, but then functions correctly when the target ID is not 0.
These CII commands should have created Take ID 0 and Take ID 2 - both from scene # 5003. But instead the command using target ID 0, messes up and creates a Take ID matching the scene ID (5003).
Sent: 06-16-2023 14:47
No, I have not repported it to your tech support.
Would that be better 2 make a ticket there?
Tue Sandbæk
TV SYD
Sent: 06-16-2023 13:38
I see, looks like a communication issue, have you called our tech support to connect to your machine and check it?
Sent: 06-16-2023 10:52
No, that is not the problem.
From the log today you can see this, when I started this morning.
*** xpciigateway v10.5 build 5535 started @ 16-06-23 03:02:2216-06-23 03:02:22.018: *** Started XPression CII Gateway v10.5 build 553516-06-23 03:02:22.182: RS232 Port 1 was successfully opened.16-06-23 03:02:22.184: TCP Port 9090 was successfully opened.16-06-23 03:02:22.184: Gateway is up and running...16-06-23 09:20:04.648: Client connected over TCP, address: 192.168.31.8216-06-23 09:20:10.563: Client connected over TCP, address: 192.168.31.8216-06-23 09:21:04.656: noop...16-06-23 09:21:04.663: Client disconnected: 192.168.31.8216-06-23 09:21:04.692: Client connected over TCP, address: 192.168.31.8216-06-23 09:21:10.706: noop...16-06-23 09:21:10.741: Client disconnected: 192.168.31.8216-06-23 09:21:10.769: Client connected over TCP, address: 192.168.31.8216-06-23 09:22:05.036: noop...16-06-23 09:22:05.056: Client disconnected: 192.168.31.8216-06-23 09:22:05.087: Client connected over TCP, address: 192.168.31.8216-06-23 09:22:11.080: noop...16-06-23 09:22:11.104: Client disconnected: 192.168.31.8216-06-23 09:22:11.133: Client connected over TCP, address: 192.168.31.8216-06-23 09:23:05.498: noop...16-06-23 09:23:05.514: Client disconnected: 192.168.31.8216-06-23 09:23:05.544: Client connected over TCP, address: 192.168.31.8216-06-23 09:23:11.555: noop...16-06-23 09:23:11.562: Client disconnected: 192.168.31.8216-06-23 09:23:11.590: Client connected over TCP, address: 192.168.31.8216-06-23 09:24:06.031: noop...16-06-23 09:24:06.035: Client disconnected: 192.168.31.8216-06-23 09:24:06.065: Client connected over TCP, address: 192.168.31.8216-06-23 09:24:12.072: noop...16-06-23 09:24:12.082: Client disconnected: 192.168.31.8216-06-23 09:24:12.111: Client connected over TCP, address: 192.168.31.8216-06-23 09:25:06.510: noop...16-06-23 09:25:06.528: Client disconnected: 192.168.31.8216-06-23 09:25:06.559: Client connected over TCP, address: 192.168.31.8216-06-23 09:25:12.561: noop...16-06-23 09:25:12.575: Client disconnected: 192.168.31.8216-06-23 09:25:12.604: Client connected over TCP, address: 192.168.31.8216-06-23 09:26:06.968: noop...16-06-23 09:26:06.986: Client disconnected: 192.168.31.8216-06-23 09:26:07.016: Client connected over TCP, address: 192.168.31.8216-06-23 09:26:13.006: noop...16-06-23 09:26:13.033: Client disconnected: 192.168.31.8216-06-23 09:26:13.062: Client connected over TCP, address: 192.168.31.8216-06-23 09:27:07.494: noop...16-06-23 09:27:07.500: Client disconnected: 192.168.31.8216-06-23 09:27:07.521: Client connected over TCP, address: 192.168.31.8216-06-23 09:27:09.488: Client disconnected: 192.168.31.8216-06-23 09:27:13.550: noop...16-06-23 09:27:13.568: Client disconnected: 192.168.31.8216-06-23 09:27:13.590: Client connected over TCP, address: 192.168.31.8216-06-23 09:27:14.070: Client connected over TCP, address: 192.168.31.8216-06-23 09:27:45.153: Incoming (raw): W\0\505\ \\16-06-23 09:27:45.153: Incoming: write page, source id: 505 target id: 016-06-23 09:27:45.154: Executed: Created Take Item ID: 0 from Template ID: 50516-06-23 09:27:45.170: Client disconnected: 192.168.31.8216-06-23 09:27:45.191: Client connected over TCP, address: 192.168.31.8216-06-23 09:27:48.192: Incoming (raw): X\RESUMEID\0\\16-06-23 09:27:48.192: Incoming: resume take id: 016-06-23 09:27:48.193: Executed: Failed resuming Take Item ID: 0 (ID does not exist)16-06-23 09:27:48.196: Client disconnected: 192.168.31.8216-06-23 09:27:48.217: Client connected over TCP, address: 192.168.31.8216-06-23 09:28:13.994: noop...16-06-23 09:28:14.006: Client disconnected: 192.168.31.8216-06-23 09:28:14.027: Client connected over TCP, address: 192.168.31.8216-06-23 09:28:48.256: noop...16-06-23 09:28:48.271: Client disconnected: 192.168.31.8216-06-23 09:28:48.292: Client connected over TCP, address: 192.168.31.8216-06-23 09:29:14.505: noop...16-06-23 09:29:14.524: Client disconnected: 192.168.31.8216-06-23 09:29:14.545: Client connected over TCP, address: 192.168.31.8216-06-23 09:29:48.845: noop...16-06-23 09:29:48.851: Client disconnected: 192.168.31.8216-06-23 09:29:48.872: Client connected over TCP, address: 192.168.31.8216-06-23 09:30:15.022: noop...16-06-23 09:30:15.037: Client disconnected: 192.168.31.8216-06-23 09:30:15.058: Client connected over TCP, address: 192.168.31.8216-06-23 09:30:49.321: noop...16-06-23 09:30:49.329: Client disconnected: 192.168.31.8216-06-23 09:30:49.350: Client connected over TCP, address: 192.168.31.8216-06-23 09:30:50.788: Incoming (raw): W\0\505\ \\16-06-23 09:30:50.788: Incoming: write page, source id: 505 target id: 016-06-23 09:30:50.789: Executed: Created Take Item ID: 0 from Template ID: 50516-06-23 09:30:50.790: Client disconnected: 192.168.31.8216-06-23 09:30:50.811: Client connected over TCP, address: 192.168.31.8216-06-23 09:31:15.555: noop...16-06-23 09:31:15.558: Client disconnected: 192.168.31.8216-06-23 09:31:15.579: Client connected over TCP, address: 192.168.31.8216-06-23 09:31:27.660: Incoming (raw): W\0\503\ \\16-06-23 09:31:27.660: Incoming: write page, source id: 503 target id: 016-06-23 09:31:27.662: Executed: Created Take Item ID: 0 from Template ID: 50316-06-23 09:31:27.663: Client disconnected: 192.168.31.8216-06-23 09:31:27.684: Client connected over TCP, address: 192.168.31.8216-06-23 09:31:30.728: Incoming (raw): X\READ\0\1\\16-06-23 09:31:30.728: Incoming: read page take id: 0 (channel: 1)16-06-23 09:31:30.729: Executed: Failed reading Take Item ID: 0 (ID does not exist)16-06-23 09:31:30.735: Client disconnected: 192.168.31.8216-06-23 09:31:30.756: Client connected over TCP, address: 192.168.31.8216-06-23 09:32:16.048: noop...16-06-23 09:32:16.071: Client disconnected: 192.168.31.8216-06-23 09:32:16.093: Client connected over TCP, address: 192.168.31.8216-06-23 09:32:31.185: noop...16-06-23 09:32:31.200: Client disconnected: 192.168.31.8216-06-23 09:32:31.222: Client connected over TCP, address: 192.168.31.8216-06-23 09:33:16.507: noop...
As you can see there is also problems with connecting and disconnecting all the time.
From yesterday is an example when running a show, but this is only overlays from mosart.
15-06-23 17:10:36.772: Incoming (raw): X\CLEAR\1\\15-06-23 17:10:36.773: Incoming: clear channel15-06-23 17:10:36.773: Clear channel: 115-06-23 17:10:36.793: Incoming (raw): X\CLEAR\2\\15-06-23 17:10:36.793: Incoming: clear channel15-06-23 17:10:36.793: Clear channel: 215-06-23 17:10:36.814: Incoming (raw): X\CLEAR\3\\15-06-23 17:10:36.814: Incoming: clear channel15-06-23 17:10:36.814: Clear channel: 315-06-23 17:10:36.856: Incoming (raw): W\1192\100\Mark Bundgaard\mabu@tvsyd.dk\\15-06-23 17:10:36.856: Incoming: write page, source id: 100 target id: 119215-06-23 17:10:36.857: Executed: Created Take Item ID: 1192 from Template ID: 10015-06-23 17:10:37.209: Incoming (raw): W\1193\602\f163.png\\15-06-23 17:10:37.209: Incoming: write page, source id: 602 target id: 119315-06-23 17:10:37.210: Executed: Created Take Item ID: 1193 from Template ID: 60215-06-23 17:10:37.231: Incoming (raw): W\1194\200\Skrydstrup\Danmark l<C3><A6>gger op til at tr<C3><A6>ne ukrainske piloter\\15-06-23 17:10:37.231: Incoming: write page, source id: 200 target id: 119415-06-23 17:10:37.231: Executed: Created Take Item ID: 1194 from Template ID: 20015-06-23 17:10:37.253: Incoming (raw): W\1195\602\vind3.png\\15-06-23 17:10:37.253: Incoming: write page, source id: 602 target id: 119515-06-23 17:10:37.254: Executed: Created Take Item ID: 1195 from Template ID: 60215-06-23 17:10:37.283: Incoming (raw): W\1196\200\Esbjerg\Vindm<C3><B8>ller smadrer nattes<C3><B8>vnen\\15-06-23 17:10:37.283: Incoming: write page, source id: 200 target id: 119615-06-23 17:10:37.283: Executed: Created Take Item ID: 1196 from Template ID: 20015-06-23 17:10:37.306: Incoming (raw): W\1197\100\Michael Tang Madsen\Hotlinekonsulent, Tj<C3><A6>reborg\\15-06-23 17:10:37.306: Incoming: write page, source id: 100 target id: 119715-06-23 17:10:37.307: Executed: Created Take Item ID: 1197 from Template ID: 10015-06-23 17:10:37.329: Incoming (raw): W\1198\701\ADRESSESKILT\\15-06-23 17:10:37.329: Incoming: write page, source id: 701 target id: 119815-06-23 17:10:37.330: Executed: Created Take Item ID: 1198 from Template ID: 70115-06-23 17:10:37.351: Incoming (raw): W\1199\104\Ellen Nybo\Vejrv<C3><A6>rt\\15-06-23 17:10:37.351: Incoming: write page, source id: 104 target id: 119915-06-23 17:10:37.352: Executed: Created Take Item ID: 1199 from Template ID: 10415-06-23 17:11:00.471: noop...15-06-23 17:11:37.686: noop...15-06-23 17:12:00.829: noop...15-06-23 17:12:38.099: noop...15-06-23 17:12:46.992: Incoming (raw): X\READ\1192\1\\15-06-23 17:12:46.992: Incoming: read page take id: 1192 (channel: 1)15-06-23 17:12:46.994: Executed: Read Take Item ID: 1192 onto Channel: 115-06-23 17:12:48.912: Incoming (raw): X\RESUMEID\1192\\15-06-23 17:12:48.912: Incoming: resume take id: 119215-06-23 17:12:48.915: Executed: Take Item ID: 1192 was resumed.15-06-23 17:12:49.003: Incoming (raw): X\READ\1193\3\\15-06-23 17:12:49.003: Incoming: read page take id: 1193 (channel: 3)15-06-23 17:12:49.122: Executed: Read Take Item ID: 1193 onto Channel: 315-06-23 17:12:49.143: Incoming (raw): X\READ\1194\1\\15-06-23 17:12:49.143: Incoming: read page take id: 1194 (channel: 1)15-06-23 17:12:49.167: Executed: Read Take Item ID: 1194 onto Channel: 115-06-23 17:12:50.531: Incoming (raw): W\1193\602\f163.png\\15-06-23 17:12:50.531: Incoming: write page, source id: 602 target id: 119315-06-23 17:12:50.531: Executed: Created Take Item ID: 1193 from Template ID: 60215-06-23 17:12:50.553: Incoming (raw): W\1194\200\Skrydstrup\Danmark l<C3><A6>gger op til at tr<C3><A6>ne ukrainske piloter\\15-06-23 17:12:50.553: Incoming: write page, source id: 200 target id: 119415-06-23 17:12:50.553: Executed: Created Take Item ID: 1194 from Template ID: 20015-06-23 17:12:50.920: Incoming (raw): X\TAKEOFFLINE\1192\\15-06-23 17:12:50.920: Incoming: take offline take id: 119215-06-23 17:12:50.925: Executed: Take Item ID: 1192 was taken offline.15-06-23 17:12:57.074: Incoming (raw): X\READ\1195\3\\15-06-23 17:12:57.075: Incoming: read page take id: 1195 (channel: 3)15-06-23 17:12:57.136: Executed: Read Take Item ID: 1195 onto Channel: 315-06-23 17:13:01.252: noop...15-06-23 17:13:19.476: Incoming (raw): X\RESUMEID\1194\\15-06-23 17:13:19.476: Incoming: resume take id: 119415-06-23 17:13:19.485: Executed: Take Item ID: 1194 was resumed.15-06-23 17:13:19.550: Incoming (raw): X\READ\1195\3\\15-06-23 17:13:19.550: Incoming: read page take id: 1195 (channel: 3)15-06-23 17:13:19.551: Executed: Read Take Item ID: 1195 onto Channel: 315-06-23 17:13:19.573: Incoming (raw): X\READ\1196\1\\15-06-23 17:13:19.573: Incoming: read page take id: 1196 (channel: 1)15-06-23 17:13:19.583: Executed: Read Take Item ID: 1196 onto Channel: 115-06-23 17:13:21.021: Incoming (raw): W\1195\602\vind3.png\\15-06-23 17:13:21.021: Incoming: write page, source id: 602 target id: 119515-06-23 17:13:21.022: Executed: Created Take Item ID: 1195 from Template ID: 60215-06-23 17:13:21.044: Incoming (raw): W\1196\200\Esbjerg\Vindm<C3><B8>ller smadrer nattes<C3><B8>vnen\\15-06-23 17:13:21.044: Incoming: write page, source id: 200 target id: 119615-06-23 17:13:21.044: Executed: Created Take Item ID: 1196 from Template ID: 20015-06-23 17:13:21.474: Incoming (raw): X\TAKEOFFLINE\1194\\15-06-23 17:13:21.474: Incoming: take offline take id: 119415-06-23 17:13:21.475: Executed: Take Item ID: 1194 was taken offline.15-06-23 17:13:28.571: Incoming (raw): W\1195\602\vind3.png\\15-06-23 17:13:28.571: Incoming: write page, source id: 602 target id: 119515-06-23 17:13:28.571: Executed: Created Take Item ID: 1195 from Template ID: 60215-06-23 17:13:28.592: Incoming (raw): W\1196\200\Esbjerg\Vindm<C3><B8>ller smadrer nattes<C3><B8>vnen\\15-06-23 17:13:28.592: Incoming: write page, source id: 200 target id: 119615-06-23 17:13:28.592: Executed: Created Take Item ID: 1196 from Template ID: 20015-06-23 17:13:54.613: Incoming (raw): X\RESUMEID\1196\\15-06-23 17:13:54.613: Incoming: resume take id: 119615-06-23 17:13:54.614: Executed: Take Item ID: 1196 was resumed.15-06-23 17:13:56.612: Incoming (raw): X\TAKEOFFLINE\1196\\15-06-23 17:13:56.612: Incoming: take offline take id: 119615-06-23 17:13:56.613: Executed: Take Item ID: 1196 was taken offline.15-06-23 17:13:57.600: Incoming (raw): X\READ\1197\1\\15-06-23 17:13:57.600: Incoming: read page take id: 1197 (channel: 1)15-06-23 17:13:57.602: Executed: Read Take Item ID: 1197 onto Channel: 115-06-23 17:14:01.703: noop...15-06-23 17:14:02.613: Incoming (raw): X\RESUMEID\1197\\15-06-23 17:14:02.613: Incoming: resume take id: 119715-06-23 17:14:02.613: Executed: Take Item ID: 1197 was resumed.15-06-23 17:14:04.609: Incoming (raw): X\TAKEOFFLINE\1197\\15-06-23 17:14:04.609: Incoming: take offline take id: 119715-06-23 17:14:04.611: Executed: Take Item ID: 1197 was taken offline.15-06-23 17:14:36.693: Incoming (raw): X\READ\1198\1\\15-06-23 17:14:36.693: Incoming: read page take id: 1198 (channel: 1)15-06-23 17:14:36.695: Executed: Read Take Item ID: 1198 onto Channel: 115-06-23 17:14:38.197: Incoming (raw): W\1198\701\ADRESSESKILT\\15-06-23 17:14:38.197: Incoming: write page, source id: 701 target id: 119815-06-23 17:14:38.197: Executed: Created Take Item ID: 1198 from Template ID: 70115-06-23 17:14:39.346: Incoming (raw): X\RESUMEID\1198\\15-06-23 17:14:39.346: Incoming: resume take id: 119815-06-23 17:14:39.347: Executed: Take Item ID: 1198 was resumed.15-06-23 17:14:41.350: Incoming (raw): X\TAKEOFFLINE\1198\\15-06-23 17:14:41.351: Incoming: take offline take id: 119815-06-23 17:14:41.351: Executed: Take Item ID: 1198 was taken offline.15-06-23 17:15:02.251: noop...15-06-23 17:15:04.019: Incoming (raw): W\1199\104\Ellen Nybo\Vejrv<C3><A6>rt\\15-06-23 17:15:04.020: Incoming: write page, source id: 104 target id: 119915-06-23 17:15:04.021: Executed: Created Take Item ID: 1199 from Template ID: 10415-06-23 17:15:04.643: Incoming (raw): X\READ\1199\1\\15-06-23 17:15:04.644: Incoming: read page take id: 1199 (channel: 1)15-06-23 17:15:04.647: Executed: Read Take Item ID: 1199 onto Channel: 115-06-23 17:15:09.648: Incoming (raw): X\RESUMEID\1199\\15-06-23 17:15:09.648: Incoming: resume take id: 119915-06-23 17:15:09.649: Executed: Take Item ID: 1199 was resumed.15-06-23 17:15:11.652: Incoming (raw): X\TAKEOFFLINE\1199\\15-06-23 17:15:11.652: Incoming: take offline take id: 119915-06-23 17:15:11.654: Executed: Take Item ID: 1199 was taken offline.15-06-23 17:16:02.793: noop...
Then there is no problem.
Tue Sandbæk
TV SYD
Sent: 06-16-2023 10:06
In all the instances I could see it was a problem with a scene ID 1003, is the a template number 1003?
Sent: 06-16-2023 09:25
Not very much more, i'm affraid of?
I've collected the logs here.
Tue Sandbæk
TV SYD
Sent: 06-16-2023 09:05
What does the CII log say?
Sent: 06-16-2023 09:02
When we make overlay graphic, it looks like that, but not when I try to load a fullscreen.
Tue Sandbæk
TV SYD
Sent: 06-16-2023 08:49
So the lines MosArt is sending look something like this?
And you see in the sequence the item appear?
Sent: 06-16-2023 08:44
No
(this was before I tryed to rename, the scene number was 503)
Tue Sandbæk
TV SYD
Sent: 06-16-2023 08:35
So its making a item ID "0" from "5003"
Sent: 06-16-2023 08:29
No, first time, it's makes take id 5003 in the sequence.
If I try again, it makes 5004 and so on.
Tue Sandbæk
TV SYD
Sent: 06-16-2023 08:24
So no item number "0" gets created in the sequence?
Sent: 06-16-2023 08:22
This should be were mosart sends commands to create the fullscreen graphic
Tue Sandbæk
TV SYD
Sent: 06-16-2023 07:54
The command is saying "0"
Show me the command which is creating the item?
Sent: 06-16-2023 07:51
No, that's the problem.
Mosart sends data to the XPression using the CII gateway.
XPresion receives somthing, and creates a new line in the sequenzer, but not with 0 in take item.
Tue Sandbæk
TV SYD
Sent: 06-16-2023 07:12
The error says Take Item 0 does not exist. Do you have a take item 0?
