  • 1.  Moving text by pixel instead of space bar
    Posted 03-06-2024 15:20
    Hi all!
    Is there a way to move a word/text line etc by pixel instead of using space bar?
    I don't have access to an Xpression keyboard at the moment so I'm thinking I need that.
    Also I need some help creating a credits crawl right to left.
    I can do one line but the issue I have is the top line is the job title and the line underneath is the name of the person.
    eg..
    Operator          Persons 2                            Person 3
    Mark                Person 2 and Person 3        Person 3
    I'm having 2 issues. The names are not always the same length. I have tried using different text objects for each job title but how do I make the job after appear in the right place?
    Thanks if anyone can help!
    Mark Isbell
  • 2.  RE: Moving text by pixel instead of space bar
    Posted 03-06-2024 16:15
    You go into layout to move things pixel by pixel when designing normally?
    Normally on the sequence side, you are just entering data and a correctly built template aligns itself as required automatically.
    However if this is a requirement just publish the other fields you need to be able to control such as x and y positions and they will show up in sequence.
