SUCCESS! Thank you so much for your help, James.
The only remaining issue is what the producers see on their end. They see the "BackgroundMat" field where they can now pick the backround. I set it to a Radio Buttons list, and it works.
But, they also see the "Number" text field that gives them the same list. They don't really conflict with each other, and they both work in changing the background, but i can see this being confusing to producers. I always like to avoid any redundant things that can confuse them.
You said the "Number" text object needs to be published for this to work, but is there any way to keep it from showing up in the list of options when published?
It's a minor problem, everything else works great. Thanks!
Kevin Coffee
Graphic Designer
Weigel Broadcasting
Sent: 01-23-2023 23:22
Subject: multiple background choice
Kevin,
In the visual logic version, first column for color, second column for index number.
Assuming you have two text objects dedicated to this, and your text objects are named the same as your columns, you probably won't have to assign columns, but if you want to keep your naming, you will assign BackgroundMat to your art layer, and number to number. The text objects need to be published.
If you allow custom values, producers can type in a new background name (until you have time to publish your project,) just so long as you have the image/material named exactly the same and in the correct place.
Sorry if I'm not understanding what part of the process has you stumped---hope I didn't gloss over something.
James.
James Hessler
WAAY (HEARTLAND MEDIA)
Sent: 01-23-2023 16:15
James (Or anyone who can help), I'm having trouble setting up the Global list. I'm not getting the process of making it work, as far as the columns. Does there need to be a new column for every possible backround I want available?
Kevin Coffee
Graphic Designer
Weigel Broadcasting
Sent: 01-21-2023 13:29
Hey Kevin,
Here's a visual logic example using two published text objects.
The input selector index offset needs to be set to "1"---select the selector, in properties at the bottom, choose 1. (The default to "0" is great for true/false, visible/not visible logic.)
Create a global list with columns named the same as your text objects so columns should be assigned by default to the correct objects or you can assign columns yourself.
Or.....
A dynamic material is another way...make a MaterialName text object, create static or global list (Static is part of this scene only. Global can be used in any scene)
A second text object & column would allow you to show producers only color names and not confuse them with your material naming conventions.
I think the @@ macro is case sensitive and some special characters may break it.
Hope this helps,
James.
James Hessler
Sent: 01-20-2023 15:18
If anyone could post an example of the Visual Logic needed for this, it would be greatly appreciated.
I keep waiting for the day when Visual Logic just appears in my head like magic, but it ain't happenin'!
Kevin Coffee
Graphic Designer
Weigel Broadcasting
Sent: 01-20-2023 12:13
Azathoth, thank you.
Kevin Coffee
Graphic Designer
Weigel Broadcasting
Sent: 01-20-2023 11:52
For choosing the background, you will want to dive into visual logic.
Make an invisible text field and publish it; use ListBox, ComboBox, or RadioButtons and turn off "Allow custom values".
From there you can use visual logic to determine what is checked. In fact, you can remove the multiple quads and make it one quad. Use Visual Logic to assign a material to the quad.
Azathoth
Son of Cthulhu
