You can't use layer objects because it only blends everything in that scene.
Remove it from the layer object, it will appear black.
Make sure its in front of the text on Z space as well.
Sent: 04-22-2024 12:56
Subject: My text not going behind mask in crawl
my text is not going behind my mask in crawl. Still shots are below to see how i set everything up. I've done mask before so i don't get what i'm missing.
thank you.
Lazaro Lopez
TV/DIRECTOR/EDITOR
MIAMI DADE COUNTY
