I have five scenes, but at the end of the crawl, it loops but it reads a line that I don't want it to read. I didn't start it there; it was working fine before. I have a line that says "miamidadecounty," which is over 255 characters long, just to demonstrate that it's a lengthy text for Excel. However, I start with n+1. If I use N, it will read "miamidadecounty."
Lazaro Lopez
TV/DIRECTOR/EDITOR
MIAMI DADE COUNTY
Sent: 03-17-2026 10:11
Subject: N Method
Normally you use 3 to 5 scenes depending on how long your strings are.
If you have a looping crawl it will just need enough items for the those so as long as you have at least 5 and then you'll start see the same messages again.
