I just tested an NDI Output Framebuffer these days, just "playtime"...
It works fine except when I clear the Framebuffer with Ctrl+F1...F2... (clear all Layers on FB), in most cases I get a "dirty" bit of a frame left on the output (fill and/or key) when I monitor the NDI Stream. Soetimes it would clear to clean Fill+Key fine (very rare) most times it just flickers one black frame and then leaves the last frame of the prior content on screen, sometimes it would leave a glitched half area of the key-content there and so forth. In either case the output is NOT cleared properly.
BUT: it always works, when I replace the prior content with an empty scene. But this is not an option as this would only clear one specific layer on the output, not all. Plus I am used to clear framebuffers by the default keyboard shortcut instead of putting an empty scene online...
Can anybody help me with this issue?
XPression Studio 7.1
NDI Tools 5 installed for monitoring the stream, but with other endpoint software for monitoring it is the same. So I would suggest it is an XPression issue.
It all happens on the same machine, so a poor network connection is likely not the cause!
Can anyone at least confirm that or even provide a solution?
Thanks in advance!
Sefa Aydemir
On Air Visuals / Switchers and Live Graphics Specialist
MMC Studios Cologne
Cologne Germany
