  • 1.  NDI Variable Input
    Posted 04-27-2020 15:49
    Hi all,
    Trying to get a dropdown for NDI source.    I'm using setsrcname but no luck in changing the source.   Any thoughts?
    Thank you
    Al
    <meta>
    <params>
    <param access="1" constrainttype="STRING_CHOICE" maxlength="0" name="InputList1" oid="Input_List_1" type="STRING" value="NDI (Output2)" widget="combo">
    <constraint>None</constraint>
    <constraint>NDI (Output)</constraint>
    <constraint>NDI (Output2)</constraint>
    </param>
    </params>
    </meta>
    <tab height="898" left="15" top="18" width="1356">
    <abs name="Tab 1">
    <abs name="Tab 2">
    <param expand="true" height="55" left="58" oid="Input_List_1" top="65" width="319"/>
    <button buttontype="push" height="40" name="Go" right="20" top="18" width="80">
    <task tasktype="ogscript">ogscript.getComponentsById('browser')[0].setUrl(params.getValue('URL1', 0));</task>
    </button>
    <button buttontype="push" height="40" left="418" name="Go" top="71" width="80">
    <task tasktype="ogscript">ogscript.getComponentsById('NDIInput1')[0].setsrcname(params.getName('Input_List_1', 0));</task>
    </button>
    <ndi height="204" id="NDIInput1" name="NDIInput1" right="961" showsrc="true" srcname="NDI (Output2)" top="180" width="296"/>
    </tab>
  • 2.  RE: NDI Variable Input
    Posted 04-27-2020 17:08
    Hi Al
    You're quite close - what you want to use is setSource(source name);
    Here is an example panel that queries for sources, puts them in a list, and allows you to select:
    <abs contexttype="opengear">
    <meta>
    <params>
    <param access="1" constrainttype="STRING_CHOICE" maxlength="0" name="NDI Sources" oid="ndi.sources" stateless="true" type="STRING" value="NONE" widget="list">
    <constraint>NONE</constraint>
    </param>
    </params>
    </meta>
    <borderlayout bottom="0" left="0" right="0" top="0">
    <borderlayout anchor="west" width="200">
    <param anchor="center" bottom="58" expand="true" left="2" oid="ndi.sources" right="3" scrolling="vertical" showlabel="false" top="5">
    <task tasktype="ogscript">var ndiWindow = ogscript.getComponentsById('ndi-window')[0];
    ndiWindow.setSource(this.getValue());</task>
    </param>
    <button anchor="south" bottom="6" buttontype="push" height="80" left="3" name="Load List" right="2">
    var sourceNames = ndiWindow.getNDISourceNames();
    ogscript.debug("FOUND" + sourceNames.length);
    var c = params.createStringChoiceConstraint(sourceNames);
    params.replaceConstraint('ndi.sources', c);</task>
    </button>
    </borderlayout>
    <ndi anchor="center" fill="fit" id="ndi-window" quality="high" showname="true" srcname="BIRDDOG-DB (SDI)" style="bg#dark;bdr:etched;"/>
    </borderlayout>
  • 3.  RE: NDI Variable Input
    Posted 03-16-2026 09:42
      |   view attached
    Hello friends, some years after
    We have an xpression 12.5 estudio, we use with NDI, 2 outputs
    Now we want to use and ndi input , we already set and NDI but we dont have a drop down menu where we can select which ndi signal we will use
    any idea how to set up?
    Alonso Valdivia
    Technical support
    Willax Tv
  • 4.  RE: NDI Variable Input
      |   view attached
    Hello friends
    we have a Xpression 12.5 studio, and we use with NDI 2 outputs
    now we need to have and ndi input, but we dont see  a dropdown menu where we can select an ndi signal.
    Alonso Valdivia
    Technical support
    Willax Tv
  • 5.  RE: NDI Variable Input
    Posted 04-27-2020 17:44
    That works.  Thank you James.
