You can avoid the rebuild by using ogscript.getComponentsById to get the NDI panel and then call panel.setImageWindow(x, y, w, h);
<meta>
<params>
<param access="1" constraint="0.0;1080.0;0.0;1080.0;1" constrainttype="INT_STEP_RANGE" name="Top" oid="Top" precision="0" type="INT32" value="0" widget="slider-vertical"/>
<param access="1" constraint="0.0;1920.0;0.0;1920.0;1" constrainttype="INT_STEP_RANGE" name="Left" oid="Left" precision="0" type="INT32" value="0" widget="slider-horizontal"/>
<param access="1" constraint="0.0;1920.0;0.0;1920.0;1" constrainttype="INT_STEP_RANGE" name="Width" oid="Width" precision="0" type="INT32" value="1920" widget="spinner"/>
<param access="1" constraint="0.0;1080.0;0.0;1080.0;1" constrainttype="INT_STEP_RANGE" name="Height" oid="Height" precision="0" type="INT32" value="1080" widget="spinner"/>
</params>
<api>function updateWindow()
var top = params.getValue('Top', 0);
var left = params.getValue('Left', 0);
var width = params.getValue('Width', 0);
var height = params.getValue('Height', 0);
var ndiPanel = ogscript.getComponentsById('my-ndi')[0];
ndiPanel.setImageWindow(left, top, width, height);
}</api>
</meta>
<ndi fill="both" height="277" id="my-ndi" left="144" quality="high" srcname="L-OTTJPELTZER4 (Test Pattern)" top="121" width="482" window="%value['Left'][0]%,%value['Top'][0]%,%value['Width'][0]%,%value['Height'][0]%"/>
<param expand="true" height="278" left="649" oid="Top" top="119" width="79">
<task tasktype="ogscript">updateWindow();</task>
</param>
<param expand="true" height="87" left="756" oid="Left" top="69" width="383">
</param>
<param expand="true" height="51" left="790" oid="Width" top="209" width="134">
</param>
<param expand="true" height="51" left="946" oid="Height" top="208" width="134">
</param>
James Peltzer
Sent: 07-31-2025 04:43
Subject: NDI Window - Seting 'Sub Window (x,y,w,h); via ogscript
Following up from Richards post as the file didn't seem to attach.
The example below uses a parameter we created called subWindowString in the definition of the NDI window so that it is evaluated when window is loaded:
<ndi height="250" id="NDI_Window" left="136" srcname="HCS_FR5 (HDX_Stream)" style="bg#BEA1A1;" top="213" width="487" window="%value['subWindowString'][0]%"/>
NDI window has an ID of NDI_Window. And whenever subWindowString is changed we just have to reload the window:
ogscript.reload("NDI_Window");
<abs contexttype="opengear" id="_top" keepalive="false" style=""> <meta> <params> <param access="1" maxlength="0" name="subWindowString" oid="subWindowString" type="STRING" value="50,50,60,80" widget="default"/> </params> </meta> <ndi height="250" id="NDI_Window" left="136" srcname="HCS_FR5 (HDX_Stream)" style="bg#BEA1A1;" top="213" width="487" window="%value['subWindowString'][0]%"/> <param expand="true" height="31" left="765" oid="subWindowString" top="216" width="468"/> <button buttontype="push" height="122" left="824" name="Reload" top="282" width="336"> <task tasktype="ogscript">/*! block id=1000 !*/ogscript.reload("NDI_Window");/*!! <block id="1000" type="ogscript_reload" x="223" y="206" w="243" ID="NDI_Window" />!!*//*!!<checksum>5e59e696c40b4d3aad4064456a6dceff</checksum>!!*/</task> </button></abs>
Daniel Bailey
Solutions Architect - Hyperconverged Solutions
Sent: 07-30-2025 06:32
I have a solution using parameters, thank you Daniel Bailey. File attached.
I would still be interested to know if there is a direct command like setSource, and if there is a document with all these commands in it.
Richard Hills
