Hey Daryl!
Here's a solution to your problem; just a quick 3-block solution using Visual Logic!
Open up visual logic for your scene (The Orange and White Block button to the right of "Window"), and there's only these blocks that you need, highlighted in Yellow:
The "Clock" block represents the current date and time.
The "Encode Date Time" block represents the day and time you're counting down to. By clicking on the block, you can enter in values for this date.
The "Time Delta" actually subtracts the two DateTimes, and outputs the Days, Hours, Minutes, and Seconds for you to use in whatever way you want!
Zachary Fradette
Sent: 04-09-2021 19:14
Subject: Need help creating a countdown clock for an event.
Patrick,
Did you ever figure out how to do this?
Daryl Judd
Sbgtv
