Yes, This is Newsroom system.
Irfan Memon
Broadcast Engineer
Samaa TV
Sent: 01-13-2025 13:11
Subject: Need help in ActiveX plugin and SDK" has been updated
Hi Irfan,
What is NMS? Is it a newsroom system?
Sent: 01-11-2025 05:48
Dear Garner Millward,
Sorry i miss to attached image,. I need to know how to integrate the MOS ActiveX plugin into my NMS web project. I got a dat file with XML data when I saved the template, However, I'm not sure how to set up an event trigger for when the "add to story button" is clicked or where the dat file is saved.
Irfan Hanif
AM Technical
Hum News
Sent: 01-10-2025 11:38
Hi Irfan,
There is no image.
I do not know what SDK you are referring to. The XPression ActiveX plugin and XPression MOS Gateway do not have an SDK/API.
What newsroom system are you using?
Do you see graphics templates in your XPression ActiveX plugin?
