Hi Jeff
This is possible. You will need to have an NK-IPS to power up the NK-GPI. You'll communicate to the GPI through the IPS.
In Ultrix in the Connections tab you will add a new connection under the servers section. Add a Ross NK Protocol server and point it at the IP address of the IPS and use port 5000.
To configure the GPI you will need to tell the GPI what commands to send when a GPI is triggered. You can set a single crosspoint or a macro of several crosspoints. Refer to the manual for more info there.
Hope that helps!
Joe Davenport
Solutions Architect
