It might be possible by ASCII but this isn't my area of expertise, hopefully, someone will see this post that has a better answer, perhaps
@Garner Millward.
Sent: 10-11-2022 15:07
Subject: Online Txt file
No. It is only sent via a txt.
Josh Udvig
CTN STUDIOS - COON RAPIDS
Sent: 10-11-2022 14:54
Are you able to format it is XML or JSON rather than txt?
Sent: 10-11-2022 13:32
I do. The txt option doesn't like web address's as a source and Rss/Http option can't pull from it. Not sure which datalinq option to use
Josh Udvig
Sent: 10-11-2022 13:03
Via datalinq, do you have a license for it?
