  • 1.  OnOffLine How to describe material shader so I can delete
    Posted 08-10-2022 16:28
    Working on a project that sets a material to a 3d imported object (basically a school color) based on teams Code "WYO, USU" I have the set shader working great. Now I am having trouble describing the shader, in the material, on the base object so that I delete that shader for the next time the scene goes on line.
    Shoutout to Jeff Reitman who really helped me out with the scripting to set materials.
    Thanks in advance.
    Malcolm Thorpe
  • 2.  RE: OnOffLine How to describe material shader so I can delete
    Posted 08-10-2022 16:44
    What do you mean by describing the shader?
  • 3.  RE: OnOffLine How to describe material shader so I can delete
    Posted 08-10-2022 16:51
    I was adding a shader to an existing material so that I could set a file to that shader. It worked great. But each time I ran the script it would add another shader. So I was trying to figure out the syntax of deleting a shader from a material applied to an object in the scene using an OnOffline script. I decided to go a different route. I just added a shader to my material and then in the script I just got that shader and changed the file attached to it. So now I don't have to delete it.
    Malcolm Thorpe
  • 4.  RE: OnOffLine How to describe material shader so I can delete
    Posted 08-10-2022 16:55
    Ah very good, I assume you're wrote something like this (which I am putting here incase people come reading the thread).
    engine.GetMaterialByName("Material1", mat)
    mat.GetShader(1, shad)
    shad.SetFileName("D:\_Xpression Projects\mProject\Images\myImage.png")
  • 5.  RE: OnOffLine How to describe material shader so I can delete
    Posted 08-10-2022 17:04
    You can also delete shaders by index number for example.
    dim mat as xpMaterial
    engine.GetMaterialByName("Material8", mat)
    mat.DeleteShaderByIndex(0)
    Would remove the first shader.
