Hi everyone.
John, try doing it this way:
1. Creat bat file with robocopy string like this :
robocopy \\{XXX.XXX.XXX.XXX}\{FOLDER}\ C:\media\ *.avi /S /MIR
(mirroring from the net folder to local). And run this bat file using scheduler of your comp (exemple one time in 5 minet)
2. If you use template links material, set in InBeforOnLine the next scrips
Dim obj As xpBaseObject
self.GetObjectByName("BG", obj)
Dim mat As xpMaterial
If obj.GetMaterial(0, mat) Then
Dim shader As xpVideoShader
If mat.GetShader(0, shader) Then
Dim name As String = shader.FileName.Replace("N:\{FOLDER}", "C:\media") 'changing path to local
shader.SetFileName(name)
shader.ReloadFile()
End If
End If
Roman Yaroshenko
chief specialist
RBC-TV
Moscow Russian Federation
Sent: 10-29-2024 15:19
Subject: Open/Stinger Videos Freezing/Stuttering
They're being played over the network.
John Henry
Technical Director
WRGB CBS6
Sent: 10-29-2024 12:06
Are you storing the clips locally on the XPression or playing them over network?
