If you have the XPression installer .exe the codec is in there, if you just run that it will install the codec on that computer.
If you want just the codec installer specifically, you can email tech support for your version.
Sent: 04-16-2025 15:55
Subject: Ou trouver les xpression codec Avi ?
"Hello, I can't find a link to download the Xpression codecs in AVI for After Effects. I'm working on two different machines. Thank you for your answers."
Ross, community, the codec comes with Xpression, correct? Sorry, but I started on an already set up system. Never set one up. Can the codec just be copied over?
Azathoth
Son of Cthulhu
